Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
Anonymous Posted on Apr 06, 2010
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be a diode or do I need to replace aux power supply.
  • Anonymous Apr 09, 2010
    Thanks for info but I found the problem and have ordered the parts to fix. Thank you
Chi Chu
Level 3:
  • Sylvania Master 8,457 Answers
  • Posted on Apr 06, 2010
Chi Chu
Sylvania Master
Level 3:
Answers
8457
Questions
0
Helped
2820440
Points
26282
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
1helpful
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
1helpful
I have a Sylvania 6842PE 42 in. I was watching TV and then there was a loud pop. The TV turned off and then I turned it back on, but there is no picture only sound. Does anyone know the problem and how to...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
My 6842pe does not turn on. when I turn on it goes green light for couple of seconds and then red light
Hopefully only your power supply is to blame. Then you can repair it or get it repaired for a little more than $150 or get it replaced for about twice as much plus the cost of labor. If you or a repair person start testing the boards and see that one or more of them have also failed then the cost of parts and labor will go up. It looks like Encompass Parts has parts still available for this television and the power supply is $194.
1helpful
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
1helpful
I was watching t.v. and the screen turn black and the sound was gone as well.and has no power at all
hello, you need to check the power supply board,check for any blown fuses or burned parts.that should be your first step. and if you don't have any repairs skills call the serviceman.
good luck
[email protected]
Seems like a fuse blew on my sylvania 42'' plasma bought in 04?
it isnt a fuse, if your fuse was blown, it wouldnt even turn on, even for a second, it is your Y-SUS board, you can order one through there website, i think
Power Supply
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
2answers
TV Noise
I hate to tell you this, but they all do it. I returned mine and the replacement does the same thing.
JJDS
Switches off
You have a power supply problem ,most likly the main board will have to be replaced, My best advice is to call out an authorized Sylvania dealer because if you make a mistake on what board is bad, they will not take it back. Play it safe. Good Luck
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
