Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Anonymous Posted on Mar 17, 2008
FDW60 Fault Hi, I have exactly the same problem. My dishwasher starts and washes ok but appears to get very hot during the drying phase and then the two lights fast and eco flash warning of a heater problem. I suspect either the heater, thermostat or control PCB. As the rest of the cycle seems of and the water gets hot then I'm assuming the heater and thermostat are OK. When the dishwasher attempts to dry is when the problem starts. Did anyone find out what there fault was? Thanks
Archie Ferrarini
Level 3:
  • Master 869 Answers
  • Posted on Jun 07, 2008
Archie Ferrarini
Master
Level 3:
Answers
869
Questions
9
Helped
335399
Points
1789
Hold down the start key and you will re- set the D/W.
Please Rate This !!! Thank YOU !!!
Won't wash
If this happens within the first. 9 secs after filling it means you have a hearing fault
1helpful
Fdw60 is flashing fast and delicate lights
The code is a10 this is normally a heating issue but could also be a foaming problem which could also be your poor washing results put a cleaner through with a lime scale remover
I have a fdw60 dishwasher when it goes through its wash cycle its starts and stops all the way through and the top spray arm does not rotate and i know the arm is not blocked there are no lights...
possibly a water pressure problem that's where I would start,could be control board get on-line parts diagram and check the diagram for other sensors that that unit may have.
Hotpoint fdw60 dishwasher, heater not heating water or drying.
If the heater is ok and the wiring is also not burnt out, then the fault will likely be the heater relay on the pcb. (Which means usually replacing the board).
Hotpoint FDW60 problem
hi
you will proberbly find that you have a control module fault.
connection from you heater and or thermostats faulty.
if your heater was open curcuit it would flash fault codes.
1helpful
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
1helpful
FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
FDW60 Fast and Eco Lights
1helpful
3answers
Dishwasher stops inbetween rinse and dry
hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
