If by killing new batteries you mean killing them by draining the power from them and making them unchargeable.. you need to take it to a Arctic Cat factory trained mechanic. There are several reasons this will happen.. the main one is the wiring is connected/hooked up wrong!! BE CAREFUL!!
yes, the amp can be used fof full range speakers. to use it a s such, the amp's "crossover" switch must be set to "off" (could also be labeled as "full-range" or "defeat").
the amp is 2 channel. 4 channel is for surround sound or to have independent front and rear channels/volumes. this 2 channel amp will support 4 speakers, but you wont be able to balance from front to back- the front and back speakers will be at the same volume all the time if both are hooked up to the amp.
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did! 800 225 5689 - MTX Customer Service & Amplifier Service Center Good luck !
