We need to know what wires you have as far as connections to the motor AND the switch. I.e. Red white black green and ______?
Is the switch resistive or just a 2 position (high/ low) 15 Amp switch?
We also need to know how the the terminals on the motor board are labeled. i.e T1, L1, T2, L2. T3, T4 etc and ground. L1 Black L2 White for high speed Green for gorund. The other 2 colors will be for the slower speed winding.
Experimenting with electricity can be costly and VERY dangerous. I would do continutiy checks on the motor windings across L1 and L2 or T1 and T2 and the same for the 2nd winding terminals. Then do the same continuity check from the power wires through the switch and verify the winding resistance across the 2 power leads in BOTH switch positions BEFORE applying power.
Most reputable pump manufacturing companies have the winding terminals on the label or included with the pump with a basic wiring diagram.
FYI you can... use a gate valve for controlling output flow from the pump and run the pump at one speed as an alternative.
I am just being honest here.. without either a wiring diagram of your pump and switch assy it is difficult to pass "safe and sound" advice to you.
Thanks for using FixYa.
Kelly
