I have tried scanning to PC and the only option seems to be email by outlook. In any case, this does not seem to work at all.
Are there any options to scan to a file on the PC?
Thanks
Open solution center click settings then scan settings. click scan to set up then select front panel list
a new window opens up showing double pane. on left handside are options to add to the right hand pane... once those options are added click update the device. re try the scan from the printer.
Did you install the HP software that came with the scanner? I believe it is called the "HP Solution Center". If so, you can open this program to scan. Once you scan the item, you will have the option of where to save the file.
HP Printer software is designed to detect only MS Outlook and Outlook Express If you are using the Scan to Email Option from HP Solution Center or HP Director. These are the only 2 mail client that you can Scan document or Pictures to Email ( as attachment while scanning )
You are using HP PSC 1610 and There is an easy option available for you to scan documents/pictures directly to Email since you are using Outlook.
for this, you will find need to check if HP Solution Center is installed in your pc ? if not, you need to install it to make things easier for you.
If you have not installed the complete software for your printer, you will not find HP Solution Center in your PC.
Download the Software from this link : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=390315#N845
There is also a printing patch available incase you have upgraded your PC from Vista to Win 7
After you have installed the S/w, check for HP Solution Center on the Desktop.
Click on Scan Document and Click on DOCUMENT to EMAIL option and click Scan, The Scanned document will automatically get scanned and Attached to Blank Email.
You need to install the full feature software installed on the PC, you would have an option to configure Outlook from the Solution center, after you configure the Outlook on the PC and install the full feature software, you would get an option scan to email, using that option you can directly scan and attach it ti email directly....any clarifications please reply....
Suddenly since last week I can not scan to my E Mail or iphoto anything. It simply says -" sorry scanner can not be initialized.
Error communicating with scanner
Yes the printer does scan to email..
All you need to check is first open solution Center> Go to Settings> And Email Settings> Checked which is the default email selected there if you hav eoutlook select it (But your outlook has to be configure to send Emails fom youe PC) then click on apply and close.
Then in solution center click on scan picture or Scan Document the in the next window where you see (Where do you want to send the scanned images) Click on the drop down and select EMAIL after it has scanned and you click on accept it should open the outlook window on its own where you can put the recepients name and send.
