Check to make sure that your voltage setting is set correctly. Look
under the turntable platter. You'll see a voltage selector. Make sure
it's properly set for your area (115V or 220V).
If this does not solve the problem, or you have a turntable that does not have the voltage setting feature, then you might
have a faulty turntable drive issue or an issue with the power, which means something is wrong on
the main board (located underneath the turntable platter).
- DJ PRO AUDIO
www.DJPROLAB.com
