Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected
by the ASCI. Sounds like it needs new logic board. Solution is first of
all you can try to reset your printer -
If it not works then try following
if reset method not works for you then you
go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
To clear error messages displayed on the LCD, you may need to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF. This should clear/reset all errors from memory.
SOURCE: canon pixma mp530 problem error code 5100
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
SOURCE: canon mp530 pixma check printer
It may be the cartridge...try removing it and then reseating it. If that
doesn't do it, clean the contacts with water or isopropyl
alcohol.(power off when you do this)
maybe this forum will explain more
http://www.fixyourownprinter.com/forums/laser/13864
