Pioneer VSX-816-K/S Receiver Logo
Posted on Apr 06, 2010
Receiver issues- VSX-816 K
The receiver is 3 years old. Since last november, i initially faced a problem with the surround left speaker not producing any sound. Sometimes it used to work, mostly it wont work. Now i am facing the same problem with Front left, right, surround left, surround back left and sometimes center. I thought it was the wiring, so i did an experiment. I took the Surround back right wire and speaker and connected to all the ports in the receiver. The ones which were giving problems do not produce sound and it works great in its own port. If i keep switching on/off the receiver, 4/7 speakers do work. But i need to keep doing it, to find out whether they work or not. Sometimes when i increase the volume, they will go off. I am not sure what is goin on? Does changing the receiver help me?
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
6457
Points
19
The speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Apr 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4674
Points
19
The speaker is broken
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
tip
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at [email protected] and i will help you the best i can
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
14helpful
6answers
Pioneer VSX D712 wont turn on. Red light is flashing. How do we reset it?
Hi, Try pushing the "Advanced Surround" and "Enter" buttons together for about 3 seconds.
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
1helpful
Surround sound doesn't work, display reads 2CH IN
Make sure surround speakers enabled in menu, select surround mode on receiver from a media source that is recorded in surround sound or the receiver can produce surround from.
2answers
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
8helpful
4answers
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
