Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Delta push down bathtub drain stop, but it is worn and does not stop the water. It does not unscrew as far as I can see how do I get it apart without removing the tube which I can not do?
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Apr 06, 2010
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
94036
Points
506
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Nov 24, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
7625
Points
Thanks for all your help. That was so easy to fix. I just had to unscrew this counter-clockwise and the plastic looking metal cap popped off and then I needed a standard screw driver to unscrew it. Jeff you "ROCK"!
Todd
How to unstop kitchen sink with garbage disposal. water goes down one side and up the other side.
There is a "p" trap in the drain.
It can be cleaned by unscrewing it.
You'll need to but a bucket under it to catch the water when you unscrew it.
My bathtub is draining very slow and I cannot figure out how to remove the stopper to clean out the problem (which is most likely a lot of hair). It is brand new...only like 6 months old...Delta brand.
On most drains, the top of the drain will unscrew, and then you can get to the rest of it. Sometimes you will have to take a pair of pliers to turn it, but it should come off.
The problem is my bathtub won't drain.
on most applications, where the lever for the stopper is located, mounted just under the faucet, also serves as the overflow for the tub: unscrew that plate and then you can pull the stopper linkage out. maybe you have a bunch of gunk (hair, etc) blocking the drain. once you have the entire linkage out, boil about a gallon of hot water and pour it down the drain; immediately follow with HOT tap water; if it drains, GREAT, if it doesn't, just let the HOT water sit there for a few minutes; then get your hand plunger and go to work. be sure to block the overflow hole (where you took the plate off) with plastic so that when you are working the plunger, you get good suction.
Apr 20, 2010 • Moen Home
Removing bath drain
Lift and Turn:
Toe Tap:
Apr 09, 2010 • Delta Home
Leaky bathtub faucet. how do i fix
Shut off water to house and drain water. Use a screwdriver to unscrew the knob, next use a pair of channel locks lefty loosey righty tighty. loosen the nut around the valve pull it out and run to the store by a like for a like. reverse instrucktions for install enjoy. eazy 25 minute job. once u have the part.
Mar 03, 2010 • Delta Home
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
2helpful
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
