Ovens Logo
Posted on Apr 06, 2010
Creda cf50g cooker oven not getting hot
Creda cf50g cooker oven not reaching high temperatures despite control turned to '9', gas is flowing and ignited but only stays at the 'slow cook' heat.
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Apr 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
9748
Points
58
Sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
I have a Frigidaire oven that's does not heat up to high temp.
If your Frigidaire oven is not heating up to the high temperature, there could be a few possible causes:
  1. The thermostat may be malfunctioning: The thermostat controls the temperature of the oven and if it's not working correctly, it could prevent the oven from reaching the high temperature.
  2. The heating element may be malfunctioning: If the heating element is not working properly, the oven may not be able to reach the high temperature.
  3. The control board may be malfunctioning: If the control board is not functioning properly, it may not be sending the correct signals to the heating element or thermostat, preventing the oven from reaching the high temperature.
  4. The oven may be in a cleaning or self-cleaning cycle: when the oven is in a cleaning cycle, the temperature is raised to a high level to clean the interior of the oven.
  5. The oven may be in a energy saver mode: some ovens have a energy saver mode that decrease the temperature by a certain degree to save energy.
3answers
Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
I would contact the manufacturer and ask for the repair manual, it does not appear to be available online. Here is a link for the contact form. Hope this helps.
Jul 18, 2008 • Ovens
RGV2-485GDN - DCS Fisher Paykel gas oven on range will not reach high temperature
Based on the information you provided, it sounds like you have already done a thorough job troubleshooting and attempting to resolve the issue with your DCS Fisher Paykel gas oven.
If the oven is not reaching high temperatures even after you have replaced the igniter and dual gas valve, and swapped the circuit board from the working side, there are a few other things you can check:
  1. Check the oven thermostat: The thermostat is responsible for regulating the temperature in the oven. If it is not functioning properly, it may be preventing the oven from reaching high temperatures. You can test the thermostat with a multimeter to see if it is functioning correctly.
  2. Check the oven temperature sensor: The temperature sensor is located inside the oven and sends temperature readings to the control board. If it is not working properly, it can cause the oven to not heat up to the desired temperature. You can test the sensor with a multimeter to see if it is functioning correctly.
  3. Check for obstructions in the gas line: If there is a blockage or obstruction in the gas line, it can prevent the oven from getting enough gas to heat up to high temperatures. Check the gas line for any debris or blockages and clean them out if necessary.
  4. Check the regulator: The regulator is responsible for regulating the pressure of the gas going into the oven. If it is not functioning properly, it can prevent the oven from heating up to high temperatures. You can test the regulator with a gas pressure gauge to see if it is functioning correctly.
If none of these solutions solve the problem, it may be best to contact a qualified technician to further diagnose and repair the issue with your oven. They will have access to a service manual and specialized tools needed to diagnose and repair the oven.
Nov 22, 2022 • DCS Ovens
2helpful
2answers
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
1helpful
3answers
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 • Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 • Creda Ovens
Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Apr 19, 2008 • Ovens
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
