My phone battery got completely dead,when i charged it i put it on and saw the welcome g1 tmobile and android after which it stays blank.so i dont know whats going on?please i need help
Re: My phone battery got completely dead,when i charged...
The battery needs to be revived when it is completely drained or when it is dead because the phone will not be able to charge it. For instructions on how to revive battery, check it here.
hi viviana escobar you can take the battery out of the phone next take the sim card out. Now put the sim card back into the phone and then the battery this should reboot your network as well as the phone. Now if after this your phone still doesn't turn on you need to a hard reset. this will wipe out all the data on your phone. To do a hard reset on your phone hold the power button and volume up and down at the same time. Next you should see a screen that should shows fast reboot erase user data. This is should help.
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
No you dont need to buy an unlock code if you simply forgot your password code, all you must do is do a hard reset on the phone. and yes you can use it prepaid or with whatever plan you want, all you do is insert your tmobile sim card, i have a flex account with tmobile and i just inserted the sim card, You dont have to contact tmobile.
Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete.
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
hi ....outthere can someone help me solve this?I have a htc {dream}G1 astriod phone...lent out to a family member....well it came back not working correctly..everything works ..but wont let me make or receive calls...found puk no. but still no good ....pls someone help me.
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
did you FULLY charge it the first tim eout of the box before using it? They say if you dont do that, the battery will never fully charge... def a bad battery tho!!!!
Tmobile puts these out and the are having nothing but issues with them being a advid user I called t-mobile and boy they where happy to replace this thing they have battery issues,screen issues,sound issues list goes on. the best thing to do is "TAKE THE MOTHER YOU KNOW WHAT BACK" and please escuse what I was about to say! But this is the best and only solution you got at this point. I have nothing but issues over Tmobile phones and service. And you got a bad battery connection problem!! RATE it please was i helpful? Rate me!!
