Glad to have been of help.
Cards bigger than 2GB won't work. The Sansa works with microSD cards. Cards bigger than 2GB are actually microSDHC (the HC stands for High Capacity) and use a different protocol. Newer Sansas such as the Fuze will use them but the e-series won't.
I read recently somewhere that newer driver software for the e280 v2 WILL allow microSD cards larger than 2GB to be used. -However when I pop my new 8GB microSD HC card in, like Calhoon above, nothing happens. Was the info on the new firmware bogus?- as I suspect? Is Sandisk ever going to offer a fix on this?
open, I don't think a firmware fix is possible, since the difference between microSD and microSDHC are hardware differences. There are newer Sansa units that do accept microSDHC cards, but they have different hardware inside.
Thanks for the reply.
I have never used the slot before. The device is full, music only, and I wanted to expand the memory. I simply bought the micro SD card and incerted it. When attached to my computer, there is no increase in capacity . There is also indication the card is even there.
I have never used the card/ slot before . Only music files are on the device. I bought the 2gb card & installed it. There is no indication on the device that the card is there. When connected to my computer, there is no indication the card is there. Also, the capacity of the device has not increased( its actuall full). At this point I don't know how to even access the card.
Sorry for the double post before, I was not sure that the first one went through.
I will try this suggestion.
Thanks
From the "Settings" menu, select USB Mode. Do you have MSC or MTP selected?
If you set it to MSC, Explorer should see the card as a removable drive.
What did you put on the card? The Sansa only plays music from the card, not videos or photos.
Where did you put your music on the card? Are they in a folder named "MUSIC"?
Did that work?
I'm sorry. The solution you described above worked perfectly. I also found that cards bigger that 2gb do not work.
thanks for your help.
