Kyocera Mita KM-2550 All-In-One Laser Printer Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why the printing profile no duplex enabled? i downloaded kyocera km-2550 driver from the internet now the printer is working fine but it doesnt print on double face ( 2 faces ) of the paper how do i fix this ???? pls.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1071
Points
For KM2550: go to printer properties; Click on device settings tab; under "installable option" choose duplex unit to installed
  • Anonymous Feb 23, 2012
    for KM2550: go to printer properties; Click on device settings tab; under "installable option" choose duplex unit to installed
Anonymous
Level 2:
An expert whose answer gotĀ voted for 100 times.
Sergeant:
  • Expert 253 Answers
  • Posted on Apr 06, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
253
Questions
0
Helped
184741
Points
802
Go to printer properties than printer priference and setting your both side printing enable
When I print it prints a code description of the document rather then the document
You need the proper print drivers. Download the drivers and update or re-install your drivers
Printer prints test page but cannot print documents
install proper print drivers. Install the KX version 6 drivers
Kyocera km-2050 print mode error
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Duplex copying
sorry but you haven`t duplex on your machine. you need to buy dublex unit or you can print on one side end insert the paper again and print on the other side.
2helpful
Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
CS 2550 software
You can find the drivers for this unit at the Kyocera-Mita America website. Follow this link to the download section and find the appropriate drivers for your operating system. I would suggest using the KX Drivers as they are the most useful and offer the greatest control of the printer.
http://www.kyoceramita.com/download/
Choose your country and then find your model of system. You will see everything listed at KM series, these are the same devices just labeled as CS for the Copystar line of machines. Find the KM 2550 driver file and download the software and install it as you would any other printer in Window or Mac OS.
I was a Systems and Technical Sales Engineer for Kyocera-Mita for more than 6 years from 1998 - 2005 and worked extensively with the R&D Teams in Japan on the development of these systems.
Hope this gets you going.
Cheers,
Keith
1helpful
2answers
Duplex
check in the printer driver that in the device settings you have duplex enabled, otherwise you cannot use the duplex unit.
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
