SanDisk Sansa e250 MP3 Player Logo
Anonymous Posted on Apr 08, 2017
Need help again
I had used the SansaUpdater, DeviceRecovery, and the firmware software's on my sansa! it worked! but i had a new problem!
after the updates and recoveries! my sansa had been restarted!
when i opened it! it had a new image! the image should only be the word "SanDisk" right? but after thoses updates and recoveries, the new image was the sandisk logo which is the sandisk on the belly of a monster (http://www.flickr.com/photos/freddykgb/187034143/) that one! and my sansa is now on a "HANG" mode!
what should i do? please guys!
  • Anonymous Apr 09, 2010
    uhmm when i turn it on, the screen is like this http://www.flickr.com/photos/freddykgb/1...
    and after that show's it only freezes, it would be on that screen until its batter goes empty!
  • srinivas0717 May 11, 2010
    it freezes saying refresh database
5 Related Answers
Anonymous
  • Posted on Dec 22, 2007
SOURCE: New SanDisk Sansa Clip freezes
Do this first:
http://forums.sandisk.com/sansa/board/message?board.id=clip&message.id=849&query.id=66344#M849
Then update your firmware:
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=718
I think you need to connect to a PC though, not sure
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on May 23, 2008
SOURCE: sansa e280 recovery mode
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Anonymous
  • Posted on May 28, 2008
SOURCE: Sansa C140 hangs while switching on displaying SanDisk Logo
My Sansa C140 hangs up while switching on, it only displays SanDisk Logo. Plz help me to solve this problem
Anonymous
  • 17 Answers
  • Posted on Jul 05, 2008
SOURCE: My Sandisk Sansa C140 only display sandisk logo
You can update the firmware. This will return your device to factory settings and fix any internal errors. All your current content will be deleted.
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
A
Anonymous
  • Posted on Sep 29, 2008
SOURCE: load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
2answers
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
3answers
Synchronize music subscription error
they want u to snc your songs now to ther sever in this new firmware update u cant go back also once updated firmware unless they offer old verison sumwar eonline u could try but ya new copyrights secuity thing snc your songs to ther website what they want i would try to see online if old fimrware like other ones is outther sumware
4helpful
2answers
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
2answers
Is there a spot for a micro chip on the sansa e250
Yes it does have a slot for microSD card on the right side
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
2answers
Dude i tried your reponse and it worked but when i turned it on again it was still at refreashing data bass what should i do?
Fimrware upgrade needed. Also, if you are running Windows Vista, you need to go to Sandisk's website and get the Vista- compatible software.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
2answers
Windows vista compatibility
ive got vista and ive had no problems with it the only thing i can thing of is that your usb port is not a high performance port
Not saving settings...
You may need to take this to a SanDisk employee or updating your firmware again. (This means waiting for a newer firmware version of Sansa e260, they may have fixed up the bugs once they have a new update.) If you have used a SanDisk microSD on this device that has been formated, please do not use it again. The microSD is not a good accersory. It'll be worth it if you're sure that you can reinstall the Sansa each time it crashes, find a more stable software if you're not willing to risk it.
3answers
Sansa won't move
Try reloading the firmware. If the Sansa Updater says that you have the lastest firmware download the firmware manually and then run the software. In addition, tech support is fantastic with Sansa give them a call or e-mail. Best Regards, Keith
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
