I recently purchased a Kenmore 30 inch induction cooktop from a Sears Outlet store. I noticed a rattle inside the unit when I was handling it. It sounded like a screw rolling around inside the unit. I removed the back of the unit and the glass cook surface and noticed that none of the four induction units were connected but were loose sliding inside the units. I can tell where each unit goes (there are locating pins) but there are four sets of terminals and I don't know which element connects to which terminal.
Any help would be appreciated.
By the way there was a loose screw in the housing.
The best way to understand how its installed would be to check out its user manual. Since you have not provided the exact model number I was unable too narraw it down to help you with correct manual. But please click on the link bellow to download the appropriate manual:
http://www.hammerwall.com/Manuals/Kenmore/9-36/Lookup/Home%20Appliances/65/
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Hello friend, thanks for your post!
I see you are searching for instructions on how to change the filter board on your Electrolux cooktop. Some of these intricate part replacements do require precision and patience, therefore when replacing electrical components or removing them from your appliance, I would suggest seeking professional assistance. One must be very careful as there certain replacement parts could result in potential harm. Best regards. -Matt
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
