DOES YOUR "POWER LIGHT" TURNS BLUE? IF NOT, IF STILL RED, YOU DONE! SYSTEM MODULE IS GONE!
OK: RELAX AND START WITH POWER SUPPLY MODULE. TAKE 3 MACHINE SCREWS(BLACK) OUT, RIGHT ABOVE YOUR IN/OUT CONNECTORS. YOU NEED TO RELEASE PLASTIC COVER, WHICH HAS A BIGGER SCREW IN A MIDDLE. TAKE ALL THOSE SCREWS OUT AND SLIDE PLASTIC GRILL DOWN, TILL YOU BE ABLE TO PRY IT OUT. THEN: SEE THE METAL SHIELD? ANOTHER 3 WHITE SCREWS AT THE VERY BOTTOM TO REMOVE.NOW, PULL IT OUT TOWARDS YOURSELF.NOTE: IT GOES INTO SLOTS AT THE UPPER SIDE. TAKE IT AWAY AND THROW IT OUT! DON'T USE IT ANYMORE! IT LACKS VENTILATION, THAT'S WHY YOUR SET QUIT!. LOCATE POWER SUPPLY BOARD(UPPER ONE), WHERE POWER CORD CONNECT TO. IT HAS 3-5 PLUGS. ONE TO THE RIGHT(2WIRES) THE REST AT THE LEFT SIDE. LOOK FOR BLOATED CAPACITORS, FIRST. FOUND NOTHING? SOME HAVE BALLAST BUILT INTO. HAS 2 18 PIN IC CHIPS ON THE LEFT SIDE AND THICK HV VIRES GOING TO THE PLUG. IN THIS CASE, YOU MUST REPLACE THIS BOARD.
IF NOT, MOST LIKELY CAPACITORS ARE THE PROBLEM.
GOOD LUCK,
ALEX'S TV.
