Ya I have the same exact problem. I got a universal all in one remote and got the codes to work with my tv a vs-6026r, but the remote does not have the needed (cancel) button. Please help!!!!
Thanks
MandyYa I have the same exact problem. I got a universal all in one remote and got the codes to work with my tv a vs-6026r, but the remote does not have the needed (cancel) button. Please help!!!!
Thanks
Mandy
You can't post conmments that contain an email address.
If you try to change the chanel on the remote and you don't get snow, then your set is in home theater mode and stuck on EXT-1 input.
You will have to get into the menu under advanced settings and turn off Home Theater.
Jack,
This Model Is Equipped With A Keyboard Lock Feature. To Unlock The Keyboard Press And Hold The "Menu" Button On The Front Panel For 10 Seconds. Then See If You Can Access That Menu Function.
Bill
No, just get a miracle remote for Mitsubishi and problem solved... http://www.miracleremote.com/ We have several here in the shop and they will operate EVERY function of the original at a fraction of the cost..
Bill
your tv is set to "Home Theater mode" . Use "menu" key on your remote, go to "advanced feature", then go to "use home theater" then hit "cancel" to return to standard mode. If this does not work try unplugging the tv for 4 hours to return to factory default settings
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Thanks
Mandy
