Keeps fashing on tv this function is not available now.
Thankyou! Jlaplante 290. I had the same problem and was going to buy a new TV tomorrow as LG Service Phone said the problem is the mother board needing replacement. You, sir, just saved me 500 quid and saved the football game on TV . Thank you so very much! I have no idea why this works and how you found out this solution. Maybe you are some kind of wizard?
Thank you Jlaplante 290. i had similar problem and contemplating going for repairs. you just helped me out now. thanks
Well... my tv was doing the same thing and some other strange things.. opened it up and found two bulging and one leaking capacitor on the power supply board! Replaced all
You may be connected to a Cable "Set-top" box, whose remote is a separate one. Either use two remotes or purchase a Universal remote to program both cable box & TV into one remote.
It is the the circuit board on side panel of tv which has the channel and cm volume control.
flashing always after a few seconds
Yes it does after a few seconds
Yes it started today
Unplug your TV and place your TV with the screen down on your couch - unscrew the backside. Lift the back side On the side where the little switch board is where you can controle the volume and menu button's. The little switch board is connected with a cable to the main board. Unplug the cable. Now can only control your TV with the remote, but now the failure message will not appear anymore. The power button on the TV can still be used as this is connected directly on the main board.
