Unplug the dryer and the first thing to do is check for the presence of
220 volts at the wall outlet. If you lost one leg of the 220 volts, it
is possible for your dryer to run but there will not be any heat. Once
you verified there is definitely 220 volts at the wall outlet, remove
the rear cover. On the lower right hand side you will see a silver
canister which contains the heating element. Remove the lower two wires
directly from the heating element and check this for continuity. If it
is good, on the left hand side of the same canister they often install a
thermal safety which may have tripped. Do the same test as with the
heating element. Remove the wires and test the thermal safety for
continuity. If this is good, move to the blower housing on the left
side of the exhaust vent and look for a white piece of plastic which has
two wires on it. Remove these two wires and check this item for
continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Its very possible that one of the parts may have been knocked out during the move. I would check the element first, then look at the t-stats. I hope this helps!
continuity.
Recheck for 220 at plug. May have tripped breaker. PULL PLUG FIRST!! Remove rear panel. Check for continuity at white thermal fuse located near bottom center on the blower housing. It should close to 0 resistance. Also check hi-limits on side of heater housing. Also should be close to 0 resistance. If any are open, replace and clear venting. Also remove 4 screws on bottom of filter housing and pull bottom of housing out. Reach in and remove lint.
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
