Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Cannot remove info display--remains on monitor continually
The info display is continually on the monitor. After shooting a picture, I can pull up that picture by using the playback button. The info display reappears when taking the next picture. How do I get this info to turn off unless I want to change or check the settings?
  • 10,865 Answers
Hello. I actually have this camera. Go into the menu and find the reset function. Reset it. This will put it at the factory settings it had the day you took it out of the box. Joe
please rate my answer as very helpful. thanks.
Posted on Apr 05, 2010
SOURCE:
Nikon d50 monitor does not work during photo shooting, must use view finder
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Apr 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
How do i use the burst mode on my nikon d3000? Thank you.
Press the Info button to bring up the Information display. Press the <i> button to place the cursor in the information display. Highlight the current release mode and press OK. Select the Continuous mode and press OK.
This lets you shoot at up to about three frames a second, depending on the shutter speed, noise reduction settings, and autofocus settings. You cannot use this with the flash.
The camera will shoot pictures as long as you hold down the shutter release button (until the buffer and/or memory card fills up). As you shoot, the viewfinder will show rNN where NN is the approximate number of further pictures you can shoot until the buffer fills up. In JPEG mode you should be able to take a hundred pictures before the buffer fills. The number will be smaller in RAW.
In AF-S and AF-A, the camera will not shoot the next picture until focus is acquired, so when shooting moving subjects or panning the camera, you may not get full speed. Even in AF-C, the camera may "hiccup" occasionally.
Mar 15, 2010 | Nikon D5000 Digital Camera
How do i turn on my d40 lcd screen
What do you want to see on it?
Press the Menu button to see the menu.
Press the Info button to see the shooting info screen.
Press the Playback button to review the pictures you've already taken.
If you want to use the LCD screen for shooting, then you're out of luck. The D40 does not have the Live View capability. The camera is designed to function as SLRs have for the last half century: you frame the picture through the viewfinder. I realize this isn't the answer you wanted to see, but that's the way the camera works.
Jan 31, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d60 does not allow me to view image whilst taking a picture
The D60 does not have a Live View capability. The monitor is used for shooting info, menus, and image reviews. It cannot be used to display the image while shooting. You must use the viewfinder for that, unless you connect the camera to a computer using the Camera Control Pro software from Nikon.
Jan 03, 2010 | Nikon Cameras
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Inital picture playback showing too much info (histogram, etc)
There should a display button on the back side of the camera. Press the same repeatedly till you select the display you like. This would ne applicable when you are shooting or are reviewing the images.
For the review of the image right after you have shot, Go to the (Rec.) Menu> scrool down to >Custom Display> set button
Here you can set the level of information you want on the monitor, you can remove the tickfrom the information you don't require.
Let me know if you could manage to remove the unnecessary info...
Mar 02, 2009 | Canon PowerShot SD600 Digital Camera
Camera settings appear on viewfinder screen
Ok I just posted that I had the same problem and I just figured it out by trial and error. What I did was
press the playback button.
press OK
it will take you to the edit picture menu and the first choice is D-lighting. It should be highlighted Yellow. press Ok and then the screen will come up with 2 of your picture with different lighting. choose which ever one you want then press OK. The image will save and then the camera info should go away. I have NO idea why this worked but it did and I hope this works for you!!
Dec 22, 2008 | Nikon D40x Digital Camera
Dark LCD screen
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jan 11, 2008 | Pentax Optio W30 Digital Camera
LCD monitor and electronic viewfinder
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
104 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
