There is a BLUE-coloured 'FN' key on the bottom-left of the keyboard. Hold that key down, and then press one of the "blue" keys, to get the "alternate" meaning of that key.
If You mean keyboard number pad Press the "Num Lk" button, which is located to the right of the "F12" key along the top of the keyboard, to turn on the keyboard number pad. The Inspiron 1525 number pad mimics the type of the number pad you would find on a larger keyboard. The blue numbers on the keys in the middle of the keyboard are activated when you press the "Num Lk" button. For example, if you press the "U" button on the keypad, a "5" will appear on the screen when the "Num Lk" is enabled. Press the "Num Lk" button again to turn off the number pad
You may just pop the key out by inserting a paper clip and popping it out. You can them fix the contact beneath it if it need to be fixed. It may also have dust, dirt or crud underneath that needs to be cleaned with some Isopropyl alcohol and a cotton tip. Be gentle and do not use force. Pop it back on as it fits on a base beneath it. You may also get another keyboard which is usually around 50 to 100 dollars and easy to replace too.
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
