Do you know how to enter BIOS Setup, and in Boot Order, change the first boot device to CDROM? If not, and you would like guidance, simply state so in a Comment.Do you know how to enter BIOS Setup, and in Boot Order, change the first boot device to CDROM? If not, and you would like guidance, simply state so in a Comment.
You can't post conmments that contain an email address.
Probably however if you upgrade the motherboard you will have to upgrade the CPU, and the memory, possibly the hard drive if the old board is IDE and the new is sata. Also you would have to upgrade the power supply if it's so old it may not have sata power connectors.
Hi, insert the cd that came with it, boot the system with it and follow step by step instruction on repairing and formatting the hard disk or get a windows operating system and perform the same.
YOUR POWER SUPPLY HAS MORE THEN LIKELY GONE
remove your power supply and take it to a pc repair store they should test it for you on the spot at no cost most of them do.
To replace depending on what you need there about 40.00
install the software it came with (drivers software etc)you will need to reboot after.
if still is not working remove the software from control panel/remove programs after remove driver and device from the control panel/device manager and perform a disk cleanup from startup/accessories/system tools/disk cleanup-stop computer and remove card.Boot again and let windows login and run for few minutes.shut down again and reinstall card.boot again and make sure the installation cd is in the cd drive.if prompted choose to install the files from a specific location and give the cd drive location .
