HP LaserJet P3005n Printer Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 49-4602 - printing error. - HP LaserJet P3005n Printer
Anonymous
Level 3:
President:
  • Master 405 Answers
  • Posted on Apr 05, 2010
Anonymous
Master
Level 3:
President:
Answers
405
Questions
0
Helped
205269
Points
1407
Check the following link, it will explain the error number 49 you have.
http://www.printertechs.com/tech/error-codes/error-codes-20-49.php
3helpful
2answers
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
2answers
What is error code 5200 on a mp830 all in one cannon printer mean?
Canon printer error code 5200 is a technological malfunction that stops printing of a canon printer. The error is registered on the screen when the temperature of the ink cartridge is high. There are no concentrations of ink present on the ink cartridges. The print head of the printer is also heated by a temperature rise resulting in an error code of 5200. Canon Printer Error 5200 Few troubleshooting steps are explained below. These troubleshooting steps are so basic that they can be performed by anybody with enough guidance. But if, in any case, someone is unable to comprehend these troubleshooting acts, assistance from trained experts is needed.
Canon printer error code 5200 is largely due to cartridge problems. This can be due to a low amount of ink in your cartridge, a faulty cartridge, or maybe there are some flaws with the logic board of your printer. We realize that Canon printers are designed to be printed in black, even if the Black cartridge is empty, using colors in the ink cartridge. Thus, if you see a mistake of 5200 in the Canon printer, the printer cartridges are either empty or near to empty. Now that you know the root of the error, let's talk about the solutions.
Our Services: You may find that the Canon printer error code 5200 has been deleted after the above information has been completed. But if you still get the same error code on your computer screen when printing, you can contact Our Printer Error Specialist now.
Check given blog.
2answers
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
11helpful
5answers
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
k24674
Grand Canyon Tech
Grand Canyon Tech
