"Not enough resources close some applications and try again"
I cannot open any application. When I try to open my text messages for example, It tells me "Not enough resources close some applications and try again"
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
May be there are some open applications in the background.Close it all if unnecessary, and try opening the desired application. Free up phone memory by moving data to a memory card.
for sending text messages : 1.go to your message settings and check the message center number to see if it is correct 2. call to your network operator customer care 3. request the message center number... 4.note it down 5. go to message settings>message center number 6. insert the number which is noted by you and save it
this solves your messaging problem ... Good luck
Sorry about the prompt on your phone, please follow the the simple steps I'll outline to close the open applications on your phone.
Step 1. Press and hold the "Home Key", you would have the open applications show up on the left corner of your screen. Scroll to 1st application you wish to close, and then ok it. Once you do this you would be in that application that is open.
Step 2. when trying to close the application that you are in right now, select on the options on the bottom left of your screen and ok exit. Once you do this that application is closed.
Step 3. repeat the process on Step 1 & Step 2 until you have just one application running on your e71, which is the "home screen".
You may want to try deleting a few old text messages from your phone or any large files (like MMS/picture messages) and seeing if that helps.
Have you added any new applications to your phone recently? It's also possible an application is automatically loading up every time you restart your phone in the background and hogging all the memory.
