See page 55 of the user manual - link below
Here is the user manual
http://www.fujifilm.ca/documents/Fuji_Z2_CM.pdf
- Press the “w” button to turn the camera on in Playback mode.
- Press the “MENU/OK” button to display the menu on the LCD monitor.
- Press “a” or “b” to select “¸” PRINT ORDER (DPOF).
- Press “c”.
- Press “a” or “b” to select “WITH DATE” or “WITHOUT DATE”. Selecting “WITH DATE” will cause the date to be imprinted on your prints.
- Press the “MENU/OK” button.
Note: When selecting the “WITH DATE” setting, the date is imprinted on your shots using the Print Service or a DPOF compatible printer (depending on the printer specifications, the date may not be printed in some cases).
- If this solutions solves you problem, please do not forget to rate my solution.
- If not, then please comment back so I can help some more
