My son is looking to replace wheels/tires for his Traxxas Slash and would like to find a more high performance tire than what came on the original vehicle (he received the Traxxas Slash for Christmas, 2009).
Please let us know which Proline high performance tires are available in those dimentions (2.2' inner/3.0" outer). He is ideally looking for a heavy duty/nobby type/high performance all terrain tire. Thank you.
Jennifer and Max Wiegers
Beadlock wheels can really change the outlook of your son's vehicle. If you are facing problems with installing beadlock wheels then follow these steps. Wish you very good luck!
http://thegrabbable.com/how-to-install-beadlock-wheels
Pro line makes a range of tires for different applications. Depending on what surface you are running on. Cement, asphalt, dirt, sand. Go to your local hobby store and pick your tires for the desired surface. I have tires for every surface. And I recommend beadlock rims. A few sets. Because tire changing is easier with these as you don't need to glue them. I use a thin layer od silicone to help the tire stay in place ie: so as not to spin on the rim.
Thanks for this I've been having similar trouble and was wondering if traxxas aluminum would help?
If you are looking for a non race tire, either the Proline Switch or Trencher would work. You can see your choices at www.prolineracing.com.
