Dell Vostro 1510 Laptop Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptops screen will not turn on and the lock with 9 keeps blinking. what is wrong with it??
Anonymous
Level 2:
New Friend:
  • Expert 113 Answers
  • Posted on Apr 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
113
Questions
0
Helped
32848
Points
193
What you saw regarding the lock with 9 is the num lock key. next to that is the Caps Lock key and next to it is the Scroll Lock key. Those are called Lock LEDs. If the status of the light is Flash-On-On then that represents system board error. Next step is reseating the processor, but requires a certified technician to do it, and if it still fails you need to replace system board or the processor of the computer.
Dell vostro blinking 9
if there is no display showing at all you may want to reset the CMOS of your motherboard. to do this try undoing the ram panel from underneath the computer. make sure the computer is turned off and the battery unplugged. remove the ram, turn the computer on and you should hear some beeping. turn the computer back off, replace the ram and then turn it back on again, this should give you video output if the screen isn't faulty
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
My screen is blank when I boot up my laptop. All the lights come on except for the screen and I noticed that the caps lock button and scroll lock buttion keep blinking as well. Can I fix this on my own...
Common issue. Your options are.
1. Replace the motherboard
2. Check out the DIY repair guide on http://www.bootmylaptop.com
3. Take the hard drive out, turn on the laptop and wrap the laptop in a towel(don't wrap the screen) for like an hour to let the heat fix it. Doesn't always work, but you have nothing to loose at this point.
After turning on the computer the screen remains black and all I see is a small blinking lock with a 9 inside. Is there anything I can do to solve this problem
sounds like you need to enter a code or password unless its for a different overseas market--lobby support line with serial number,,they might be able to tell you market ect
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
1helpful
2answers
My dell vostro1510 comes on but the screen doesnt the lock key with the 9 keep blinking
Try reseating the RAM modules, see if any change. If none, try the modules one at a time
When I press the button to turn the laptop on it won't come on
something might be wrong with your computer have you changed any of your computer specs? like video card, ram, anything unusual you might have done?
Screen does not work
Did you try to start in safe mode? Turn on the laptop and start tapping the <F8> key. This will bring you to a menu with different options and select ‘Safe mode”. If that doesn’t work, try connecting an external monitor to the laptop. You may have to select the video output to display on the external monitor by holding down the blue <FN> key and pressing the blue CRT/LCD (located on one of the <F> keys, like F8,F9, etc..).
If the laptop display works in safe mode, then you probably have a video software driver problem.
If the display works on the external monitor in normal mode, then you probably have a problem with either your LCD panel.
Hope this helps.
By the way, the "9" led with the pad lock means your "Num Lock" is enabled.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
