I'm sorry to hear that you're having trouble with your Paradox alarm. Unfortunately, without access to the specific manual or programming instructions for your MG10LEDH model, I am unable to provide you with the exact code to stop the alarm from going off every hour.
However, it is possible that the issue may be related to the alarm's timer settings or an automatic test mode that has been activated. You may want to try checking the alarm's programming manual for instructions on how to disable any automatic test modes or adjust the timer settings.
If you are unable to find a solution on your own, I recommend contacting the manufacturer or a certified Paradox alarm technician for assistance. They should be able to provide you with more specific instructions or diagnose and fix any issues with your alarm system.
I just got a M.Z. Berger AW206 366 so the setup should be identical.
The watch has four buttons total. I'll name then by their positions. Top Left (TL), Top Right (TR), Bottom Left (BL), and Bottom Right (BR).
(BL) is your mode switch. Press it once at a time to toggle between modes, (Time, Chronograph, and Alarm). From the Time mode press (BL) three times. This will put you back in time mode with the seconds flashing. Press (TR) to toggle seconds back to '00'. Press (BR) to toggle to the next setting point, and (TR) to advance it. Just keep pressing (BR) until all the settings points are the way you want them. Note: In time setting mode it only advances the setting forward when you press (TR). So when using it to change hours display for 12/24 hour display or daylight savings time you just have to keep advancing the hour until it shows up correct. There is no DST or 12/24 display toggle on this watch. You just have to change the hours display manually. To exit time setting just press (BL) once.
First, go to the time mode which displays week day, seconds and timeas opposed to calendar, seconds and time. To do so, touch and hold upper left sensor until the watch beeps. Then use the upper right button to switch to the proper time mode. Then touch and hold lower right sensor. This will send the watch into settings mode.
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps: 1. Press Lap/Reset and hold. You should see the time the alarm was set for. 2. While holding Lap/Reset, press Mode. 3. Let go of all buttons. 4. There you go!
