Well like most carries I believe tracfone will not let you use a tmobile sim card because the phone is locked to tracfone only. Typically you could unlock your phone to use with any service provider that uses sim cards. However I do not have the process instructions for your particular phone model.
You can purchase unlocked phones on amazon.com, ebay etc. If you are satisfied with your tmobile service perhaps you could always get a tmobile phone.
Post back if you have any further questions. Thank you for choosing Fixya.
You need to get the phone unlocked. Either call tmobile and request an unlock code or buy one online. This code will free your phone from the Tmobile lock and you'll be able to use it on any GSM sim card.
Try Following Techniques First Trick : For Master code calculation http://www.nokialockcode.com/calculate.php and enter it to unlock. For IMEI *#06# Second Trick : 1.press "unlock" button 2.then press "back" 3.then deep press unlock and then suddenly press * 4.that's all you unlocked the phone successfully. NOTE: it will not work on all nokia phones so please check the nokia phones before practising the trick;but the trick can effectively work on most non java enabled nokia phones Third Trick : Remove Your Sim Card, Power The Phone On Press # From The (Insert Sim) Screen Enter codes WITHOUT spaces. Press * 3 times fast for (p) Press * 4 times fast for (w) Press * 2 times fast for (+) Verify code before pressing the last # Fourth One: The only way you can reset the security code is to take it to Nokia or some mobile store where they will reset it using a flash cable. I hope this will help full to you.
I assume you are asking about unlocking your phone. If you are a tmobile user than any tmobile sim will work in your phone even if your phone is locked. When a foreign or different compatible sim is inserted your phone will ask for the unlock code if your phone is locked. When you have an unlocked phone it automatically accepts the sim and does not ask for the unlock code since your phone is unlocked.
i have the PUK code to unlock t-mobile sidekick slide. buuuuuut, its not free. [email protected] if you would like the code please send $10 through paypal. if not, keep searching to find the PUK code.
