Home Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on May 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
16554
Points
42
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
UsedClockPartsdotCom
Level 3:
  • Seiko Master 277 Answers
  • Posted on Dec 16, 2016
Seiko Master
Level 3:
Answers
277
Questions
0
Helped
146996
Points
4537
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Tim
UsedClockParts.com
James Wesolek
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 25, 2014
James Wesolek
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7213
Points
How do you set the chimes for the exact time to go properly
on a Linden wall clock
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
1helpful
I have a Linden mantel clock with chimes and 3 winding squares. Which square is for which function? I cannot seem to find this info anywhere!
I believe the one on the right is for the chimes, the one in the center is for the time and the one on the left is for the gong (on the hour).
Main Page
Nov 01, 2016 • Home
2answers
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 • Home
Clock chimes
What is the problem? Linden is a German manufacturer... I work on German timepieces daily.
2helpful
Linden mantel clock
Make sure all the batteries have been replaced, that the batteries fit tight, check for loose wite connections. If that is all good, you will need to replace the chime box or the whole movement.
Jan 10, 2014 • Home
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
Fix Clock That Gongs Wrong
5helpful
3answers
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
1helpful
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Top Seiko Home Experts
ZJ Limited
ZJ Limited
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Seiko Home Expert? Answer questions, earn points and help others
