Our washer works fine until the spin cycle. The drum spins and the agitator spins until the end of the spin cyle. At this point the drum spins, but the agitator stops spinning and there is a knocking noise. HELP!
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Hello, it is the drum shaft collar or what the tub rests on. It is on the top of the shaft. You need to remove the shell, the plastic collar that rests on top of the drum, the agitator, then the nut that holds the drum down, and then pull the drum out, and then you will see the collar. I know it is hard to get to so I would call a pro for this job unless you think you can do it. The part is cheep it is the labor that will cost you. Thank you
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK. It would not agitate unless both are OK. (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter. There is a separate tube for spinning the basket. There is a drive block at top of the tube (that sometimes fails) and there is a separate cluch mechanism below, under the tub. Those places is where you should look.
The timer itself is bad, replace and wala!
Timer
Part Number: PT756240
Made by MAYTAG
http://www.partstap.com/partsearch/model.aspx?model_id=47859
$70.22 + S&H
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
