SOURCE: how to replace valve cover gasket 1998 chevy malibu
The first step is to remove all the parts that are in the way of you being able to remove the valve covers. (Ex.: air intake, loose wires etc.) Then you will need to remove your valve covers (using basic tools) and be very careful to not let anything get on your lifters, which your valve covers protect. Once you have the valve covers off compare the new gaskets to make sure they are the right size. Then remove the old gasket and replace with the new one using a high temp gasket sealant (available at any auto parts store) to attach the gasket to the valve covers. Then tighten down snug and check for leaks after replaced.
SOURCE: 98 chevy malibu:engine wont turn
Check with a battery tester if you have power at the starter, Are the Battery post clean, Are any fuses blown in the fuse Box, check for any corrision.
SOURCE: 2006 chevy malibu.... where is the egr valve
If it's a US car then there is not an egr on the 2.2L engine. I think some of the mexican and oversea's engines had them, but not here in the US.
SOURCE: Slightly adjusting the timing chain on a 98 Chevy
Your playing with fire to try to adjust something thats not designed to be adjusted even the hi dollar fancy racing teams are very careful going any from the factory specs as they have dynos and scopes and way more money to spend than me and you. No stock engine being used as a daily driver should be changed unless it's back to standard. Your stepping into deep **** unless you have deep pockets to deal withblown mototers and other bad stories. I know them and I can write them
SOURCE: Where does the flasher go on a 98 chevy malibu
Replacement
The turn and hazard flashers are integrated into one flasher on these models. The flasher is located in the hazard warning switch and the hazard warning switch is located on the trim plate. Replace the flasher by unplugging the old one, removing it from the panel, and plugging in the new one.
Remove the bezel from the ignition switch
Carefully remove the instrument panel accessory trim plate.
To remove the trim plate, use a suitable prytool to carefully apply pressure at the retaining clip points . . .
. . . then gently pull the accessory trim plate away
Detach the electrical connector from the hazard warning switch.
Unplug the electrical connector from the hazard warning switch . . .
Unfasten the screw securing the hazard warning switch and remove the switch.
. . . then unfasten the screw securing the hazard warning switch and remove the switch from the vehicle
Installation is the reverse of removal.
Testimonial: "just what I needed, thank you so much."
