There is probably a small, secondary battery in your camera. It doesn't
power the photo taking parts, only the date keeping and so on. Perhaps
it is dead. Take it to a camera store and ask about it.
The camera records the date and time of each photo in the
metadata attached to each picture. You have the option to see the date
and time when when the camera is in "Playback" mode, which allows you to
preview your images on the screen. When looking at your pictures, use
the "Disp/Back" button to include text with your pictures. The date and
time will appear along the bottom of the image.
Printing the Date on Pictures
Users can include the time and date on their prints from the "Mode" menu by choosing "Print Order" with the "With Date" option.
Hello! Welcome to FixYa! According to the review features of Sony Cyber-shot DSC-T10 Digital Camera, this camera doesn't have a feature for superimposing date/time on images, however you can print images with the date superimposed, So by default u cannot put the time or date stamp on your images, but after taken the images you can manually put the stamp and can print the images. Don't hesitate to let me know if you want any further assistance. I hope this solution helps you Thank you and Keep using FixYa!
The date and time are stored with every image. Any photo editing program should be able to show you that data (and a LOT more); look for something like "image info" or "EXIF data". If you want the data printed with the picture, refer to the documentation for whatever program you're using to print. Depending on the program and the printer, you may be able to display the date and time on the image, in the margins, or on the back.
Issue: How do I reset the camera to its default settings? Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000.
1. Turn on the camera and press the <MENU> button to open the menu.2. Using the button, highlight the yellow (Set up) tab.3. Using the button, select [Reset All..] and press .4. Select [OK] and press .
Settings cannot be reset when the camera is connected to a computer or to a printer.
The following cannot be reset:
Shooting mode
The [Date/Time], [Language] and [Video System] options in the (Set up) menu
White balance data recorded with the custom white balance function
Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
By default Olympus cameras do not print or show the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
However the computer will only show the date information as part of the photo properties.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reserve that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
NOTE:
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information Phone: 1-877-388-3779 Email: Click Here Customer Support Hours: (Mon - Fri:) 10:00am - 7:00pm EST (Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
