The clog is most likely not right there at the disposal. It's probably further down the drain. If you wait a good long while (an hour or two) before you run the water, then run the water to see how long it takes to back up, you can get an idea of how far along the drain the clog is. Hopefully you have a clean-out port where you need it. A drain snake may be needed.
By the way, a common clogger is to run a bunch of peels through the disposal then not run enough water to chase them all of the way to the larger diameter drain.
The drain out is clogged...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
