SOURCE: my ps3 has a red error screen saying contact tech. support
check security settings? may need to reset.
SOURCE: When i turn on my ps3 a red screen comes up
Usually it's a motherboard issue, but you can try booting the PS3 WITHOUT the hard drive installed and see what happens.
Let me know.
SOURCE: PS3 is "on", red screen has occurred with a error warning
this is probably an warning about problems with your hardware (such as gpu or ram modules) .
The only thing you can do is taking the system to an assistance centre for hardware checking, they will test all the components of the system .
if your system is covered by warranty, don't waste time and call sony as soon as you can !!
unfortunately, there isn't any firmware solution to fix it, because all system functionality is prejudiced.
the only thing you can do (i belive it wont work), is reseting av settings by holding the on;off button when starting up the system .
SOURCE: {ps3}a serious error has occurred.
contact sony
your hard drive has failed
mine failed 3 mos after my warrenty was over
I contacted Sony and was amazed.. NOT only did they take care of it free of charge they actually sent back an 80 gig
