Altec Lansing BackBeat Plus Mobile  Headset Logo
Posted on Apr 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect my backbeat 903 to my phone - Altec Lansing BackBeat Plus Mobile Headset
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3427
Points
25
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics web site)
  • Anonymous May 19, 2013
    thank you i had just rebooted my phone and i was able to pair it again. even better, i was able to figure out how to pair it with my laptop. thank you so much!
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Altec Lansing Master 1,001 Answers
  • Posted on Jan 10, 2017
wwlvictoria
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603956
Points
6027
2 Related Answers
Anonymous
  • 7191 Answers
  • Posted on May 01, 2010
SOURCE: BACKBEAT 903 manual
You can download the complete instruction manual in PDF format by clicking this link.
For more details, features and specifications, click here.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Anonymous
  • Posted on Aug 06, 2011
SOURCE: Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
When i listen to my music from my phone with my backbeat 903, the music skips like a sratched cd. why is this?
Here are a few things you can try to see if they will improve the quality of the sound:
You should always make sure that your mobile phone is located on the left side of your body and that there are no obstructions between it and your headphones.
Also make sure that your headphones are within 33 feet (10 meters) of your mobile phone. Going outside of this range can impact audio quality.
You can also try resetting the headsets and see if that will help.
While plugging in the AC charger, hold the power/pair button.The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903-906 User's Guide, which may give you some more suggestions.
Plantronics Backbeat 903-906 User's Guide
Good luck from Headsets Direct!
1helpful
I can not configure Backbeat 903 + with android LG Optimus 509
It sounds like you need to prepare your phone to connect to the headset. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on. Make sure there isn't any other bluetooth interference and then pair the two devices following the instructions from the user guide in the link below for the Plantronics Backbeat 903+.
Plantronics Backbeat 903+ User's Guide
I cannot turn on my brand new plantronics headphones. please help me!
Can't turn on the Plantronics BackBeat 903 headset:
The power button for the Plantronics BackBeat 903 headset is on the back of the ear piece. Please take a look at the user guide, it has a diagram. Here is the link:
http://www.headsetsdirect.com/pdf/backbeat903-906_ug_en.pdf
Good luck from Headsets Direct - 800-914-7996.
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
I have my backbeat 903 synced to my ps3 and phone how do i switch to my phone when i leave the house and back to the ps3 when i want to use it in gaming
If you have the BackBeat 903 synced (or paired) to both devices, you should be able to toggle between the two seamlessly. The multipoint technology that Plantronics uses to pair its headsets to two devices at once works on a first ring basis. When you're out and about with your phone, the headset will respond only to it (33' bluetooth range for one thing). When you're paired to and having fun on your PS3, if your phone rings, you make the choice to keep playing or answer the phone. You're always in control, one doesn't override the other.
I have a Plantronics Backbeat that I use with my iPhone 3G. Many people complain that it is difficult to hear me when I speak on the phone. The say there is a lot of drop out and that it isn't clear. ...
again the battery for a few seconds, then replace the battery and turn it back on again. Delete any pairing information for your BackBeat 903 headset from the phone and pair it again with your phone, carefully following the instructions on the following link for the Plantronics BackBeat 903.
That should get the cobwebs out of the connectivity between the headset and the phone.
2answers
Will not fast forward a song and when i pause it it only mutes the music and keeps playing the song on my phone
Typically with the Plantronics Backbeat 903 Bluetooth headset, you should be able to move forward or backwards one track. Press and hold the volume/tracking/mute button forward or backwards for each track. You should hear a single low tone for each track change. Below is a link for the Backbeat 903 user guide.
Top Altec Lansing Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
