Sameer
unlocking mobile
Hi, For mobile unlocking use this http://www.theunlockarena.com/ site's unlock code ,here only i got my successful unlock.you can also enter provider your mobile,mode,network,country,etc details then get unlock code and successfully unlock your mobile.All the best.
IME35832302-450396-7-32
Unlocking information -
Method 1. Unlock your phone for freeThere are many websites which simply list codes for your phone without charge. Many people believe the practice of locking phones is anti-competitive and thus there's a lot of information to help consumers fight back against this.
Who is this for?
The free method works best for older Nokia phones and some other older handsets. Yet its worth everyone quickly trying to see if you can find a code for your phone, though after trying that, go toMethod 2.
Step 1. Get your facts right.
To find a working unlocking code for your handset, you need three pieces of info; its brand/model number, the network, and the IMEI code. Here's how to find them.
Step 2. Find an unlocking code.
There are a raft of websites dedicated to phone unlocking. Which you should head for first depends on your handset brand.
If it transpires that you can't unlock your phone with a free code go to Method 2.
Step 3. Use it!
The sites above will generate a code based on the info you provided, so double check it's right first. The code will look something like this. #pw+2746763089+1# (Nokia phones), or *2767*637# (Other makes).
To unlock, take the Sim card out of the phone and put in a different network's Sim. Now you can put the code in...How to enter the code.
Rather than using the regular text keys you need to use the * key if you want to produce letters as opposed to numbers. To produce a ‘p', press the * button three times within two seconds; to produce a ‘w', press the * button four times within two seconds; to produce a ‘+', press the * button twice within two seconds.
You should now get a message saying ‘phone restriction off' (or words to that effect). You only have five attempts to enter the correct code so be extremely careful. If none are successful, the phone will still work, but you'll have to go to the network or a retailer to get it unlocked instead.
Method 2. Buy a codeIf you haven't found a free code, it may be possible to buy one. Obviously the aim here is to find the code as cheaply as possible and it's only worth doing if the reason you're going to unlock your phone will save you more than the cost.Who is this for?
This applies to most modern handsets, so it's always worth trying, but if it doesn't work then there's still a chance using Method 3.
Phone your current network and ask it how much it'll charge for an unlock code. Unfortunately, networks tend to play fast and loose with their unlocking fees, to the extent it often seems they're making them up as they go along. You may be quoted anything between £20 and £120, depending on your handset, network, and it seems, which way the wind is blowing that day.
Vodafone is the only exceptions from all this cloak-and-dagger pricing; its contract customers can get phone unlock codes for free regardless of how far into the contract they are, and so can Pay As You Go customers provided they've been with the network for at least 12 months. If not, a reasonable flat-rate £19.99 is payable.
Important note: If your network cannot quote you a price for an unlock code, then the chances are your phone isn't unlockable by code (they should tell you this if asked). If that's the case, don't bother looking at other sites that sell codes, they may charge you just to tell you it isn't possible. Go straight to method 3 instead.
Having got a benchmark unlocking price from your network, you can hit the web and the high st. to see if they'll beat it. If looking online, be sure you know exactly what you're getting before you pay; read the terms and conditions to make sure they won't fob you off with something other than the code you need. Also, always check the legitimacy of sites; there are some dodgy operators working in this business.
Whilst the web's probably not the best place to look, it's likely there are businesses offering mobile unlocking on your local high street. Check phone shops, markets and even some newsagents and key-cutters; they might be cheaper. The added advantage of these is that if they can't do the job you won't be charged, whereas on the web you may pay regardless.
It can take anything between 15 minutes and a week for your code to come through, depending on the network. Once it arrives, follow the instructions in method 1 to put it into the handset.
Hope I helped
Dr Reed - Unlocking expert
Are you looking for the security code to unlock the cell phone so you can use the phone with a different phone service provider/SIM card?
