I try to open hp dv2-1030us screen but couldn't do it, cause something its holding center, top ,bottom ,right n left sides right in middle, any idea what is holding or what to do. thanks
Http://h10032.www1.hp.com/ctg/Manual/c01682742.pdf
Click the above link
this is the service and maintenance manual specific to your model. It should provide you with enough information to complete the job if you end up needing some help, drop me a line. good luck!!
Testimonial: "they had instructions on how to remove front screen bezel"
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
