GE 25952EE1 Cordless Phone Logo
Posted on Apr 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After connecting to a telephone line, the handset starts ringing
Anonymous
Level 2:
New Friend:
  • Expert 142 Answers
  • Posted on Apr 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
142
Questions
0
Helped
17363
Points
402
Just take out the connection
How do i get volume on my binatone 3325 handset
Press C/8 to unmute the microphone.
complete installations
Plug the power adapter
& line cord
into the base station.
Plug the power adapter into a 230Vac, 50Hz
mains socket, the other end of the line cord
into your telephone line socket.
Warning: Always use the line cord provided in the box.
Other line cords may not be compatible and may not work.
Warning: Only use the power adapter supplied.
Others will result in non-compliance with the safety
specification EN60950, and will invalidate any approval
given with this apparatus.
Warning: The Base unit needs mains power for
normal operation, not just for charging the handset batteries.
Installing and charging the batteries
Slide open the battery compartment cover.
Place the 2 batteries with the correct polarity,
as shown.
Slide the battery compartment cover back.
Put the handset on the base and charge for
15 hours before first time use. The handset
beeps when charging starts.
Warning: Only use the AAA size NiMH rechargeable
batteries.
If you have a Broadband Line
If you connect your telephone to a line with a broadband connection, you will need to
insert a micro-filter between the telephone and the telephone line, otherwise you may
get interference between the telephone and the broadband, which could cause
problems.
In a home with broadband, every telephone must have a micro-filter connected, not just the one at the telephone point that your modem is connected to.
If you need more broadband micro-filters, contact your broadband provider.
Connection and Conditions for use:
You can connect your phone to a direct exchange line (DEL) on a local
exchange with its own phone number; to an extension socket
connected to a DEL; or to an extension on an approved compatible
PBX. Do not connect as an extension to a payphone.
The ringer equivalence number (REN) of all equipment (phones, fax
machines, modems, etc.) connected to an exchange line must not add
up to more than 4, otherwise one or more of them may not ring and/or
answer calls correctly. This phone has a REN of 1, and most other
telephones have a REN of 1 unless marked otherwise.
Handset - Base Connection
1) When purchased, all handsets are already registered to the base unit
and should link to it when they are all powered up.
2) To use your cordless handset and base unit together, you must be
able to establish a radio link between them. The signal between the
handset and the base is in accordance with the normal standards for
a DECT phone: Maximum range up to 300 metres outdoors or 50
metres indoors. Be aware that:
> Any large metal object, such as a refrigerator, mirror or filing cabinet,
between the handset and the base unit may block the radio signal.
> Other solid structures, like walls, may reduce the signal strength.
> Other electrical equipment may cause interference and/or affect the range.
3) Do not place close to another telephone, a TV or audio equipment - it
may cause interference.
4) Out of Range warning. If you hear a warning tone during a call,
and/or the sound in the earpiece becomes faint or distorted, you may be
going out of range of the base unit, so move nearer to the base unit
within 20 seconds, otherwise the call may be cut off.
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
When my home phone rings my internet disconnects
You need to make sure that you have an ADSL line filter connected before any home telephone or DECT base station (eg. a filter is required on the line between your physical telephone device and phone socket). This can also be achieved via a central ADSL phone line splitter.
---------- ADSL Filter -----> Telephone Handset 1 or DECT base station
<--- main telephone line --/
\-----------------------------------> ADSL Modem/Router ---> Computer
\----------ADSL Filter -----> Telephone Handset 2
Hope it helps: let me know how you go.
Dec 13, 2010 • Cell Phones
2helpful
2answers
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
1helpful
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
Phone continues to ring after going off hook
5 Miles! Wow.. after about 300ft.. i have had problems it is because of the drain on the line i am really surprised that a low voltage current could even carry that far i would recommend you get a telephone line amplifyer to solve this problem.
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
One one ring tone with incoming call..........
Make sure the ringer is on .
• Make sure the telephone line cord and power adapter are plugged in properly .
• The cordless handset may be too far from the telephone base. Move it closer to the telephone
base.
• There may be too many extension telephones on the telephone line to allow all of them to ring
• If the other telephones in your home are having the same problem, the problem is in the wiring
• Other electronic products can cause interference to your cordless telephone. Try installing your
• Test a working telephone at the telephone jack. If another telephone has the same problem, the
problem is in the telephone jack. Contact your local telephone company (charges may apply).
• The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
• Remove and re-insert the battery and place the cordless handset in the telephone base.
• Wait for the cordless handset to synchronize with the telephone base. Allow up to one minute
for more info download this http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i3.pdf
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
