heres how.. hold source button down until radio turns off and clock is visable. nexst hold audio button down untill clock starts to blink. audio btn is top right hand button next to arrows. next choose hr or min and use up arrow to go up and down to go down
the amplifier inside the unit has failed. you can verify by hooking up an amplifier and using the RCA jacks for your signal. If it works - the radio's internal amplifier is in need of repair. Something will have caused the problem - so in the meantime - check the speakers for shorted wiring or burned voicecoils.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
