Is that mean it is charging??? Been pluged in over 6 hrs and has not turned green yet. Can't find my charger instructions. Just wanted to know how long it takes or do I need to change something
Thanks
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
