RCA 25415RE3 Phone Logo
Posted on Apr 03, 2010
How do I undo call forwarding on an RCA 25415RE3-A telephone?
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 45 Answers
  • Posted on Apr 19, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
45
Questions
0
Helped
18585
Points
66
Call forwarding is a function of your service provider. CALL FORWARD VARIABLE you control by dialing a code then then number you wont to forward your calls to, *72-685-2900. To disable the forward dial *73. There are different codes for each phone company, you may have to contact them for the code they use.
Another type of forwarding is setup by the phone company, CALL FORWARD BUSY/NO ANSWER. This type of forwarding you have to call the customer service line at your phone company to have them remove it. I use this type for my voice mail and call routing service, All Call Technologies.
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Un forward line
Normally it's *72 to forward calls and *73 to cancel. If that doesn't work, contact your telephone company for their instructions regarding call forwarding.
I HAVE A RCA MODEL 25415RE3 FOR OVER A YEAR, AND
I have the same problem, its plugged in, the dial tone is there but the display is not working. Can someone help us?
2answers
We use an RCA 25415 in our office and can not get the intercom to work, any suggestions?
http://www.rca4business.com/products/pc/pdf/instruction-book/25415RE3.pdf
If you click on the above that is your manual.
go to page 10 for Intercom auto answer.
and page 19 for Intercom calls .
Hope it helps!
1helpful
2answers
RCA 900 MHz Accessory Handset- H5400RE3 for 4-line systems 25413RE3, 25414RE3 & 25415RE3
Donna75603,
Go near the base of the corded phone to register your cordless phone. Press "menu" on your cordless phone and press arrow key till you see "Registration". Press "Select" key. The sreen will show "Yes" and "No" sign. Press arrow key once to select "Yes" then press "Select" key. The sreeen will show "Registerring.." , at this time press "Page" key on the corded or base phone and hold it for a few seconds until you hear a beeping sound. This is the sign the the phones are syncronized. You can now use your cordless phone.
Jun
Brooklyn
2helpful
RCA 25415RE3
All of the "features" you are having problems with require AC power, I think you have a bad power supply, the plug on the phone is bad or something inside has fried. If you have tried switching the power adaptor with one that you know works then look at the plug in the phone. Make sure the contact is clean and not damaged. If this does not work you may have to replace the phone.
2answers
GE RCA 25415RE3 Integrated 4 Line Phone+Call Waiting
On Page 28 in your manual.
Part number is 5-2651
1helpful
2answers
Phone is not recording all messages left
The 25414RE3 isn't the model with the answering machine. The one that has the answering machine is the 25415RE3.
As for the problem, does the answering machine part of the unit actually pick up the line? Does it announce your pre-recorded message? Does it just not record the caller's response?
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
