Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
Turn off the camcorder.
Remove the battery from the camera.
Remove the AC power supply from the camera.
Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
Hi, The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck, In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment. Hope you will understand my sayings. Thanks for using fixya.
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
PLEASE DO NOT RETRACT IT BACK manually doing so ,will DAMAGE more the unit ,what you should do is plug the Video Camera AC plug and press the EJECT BUTTON , OR TRY turn in ON & OFF , TO SEE if it works.....
Sony camcorders C:31:23 error Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. good luck
please mark the post with a fixya
Dirty video head! Playback newly opened blank tape for
five minutes, after that eject, reinsert, playback
then eject again five times, these will serve as your
video head cleaner, never use "video head cleaning
cassette tape" for it will only damage your camera.
Most camera has built in video head cleaner
installed inside and activates only when you insert,
initial play/rec, and ejects a tape. If the problem is
still there you need pro fix then.[:0)
