Our unit is hooked up to a hose drain it has been working well until Monday the bucket filled up and didn't drain and the unit turn off what could cause it not to drain the hose is clear
Check to see if the hose adapter tube has become dislodged from the fitting inside the dehumidifier. You can see this connection if you pull the bucket drawer out and look in the top right-hand corner of the opening on the unit. You should see a small black L-shaped tube that comes from the water collector tray under the condenser. It mates with the white hose adapter tube when it is installed properly. If the connection isn't made the water will drain into the bucket instead of the tube and garden hose. Good luck!
Proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
