I replaced my pressure switch and I ran a wash with no clothes.Washer worked great. Put my first load of clothes in and its running great.(here's my problem) In the spin cycle,right before it hits max speed,the washer stops spinning and all the lights go out.
Is it the motor overloading? What should I do.
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
This is a front load washing machine.Door can't hit the timer. Door does lock and the drain is clear of obstruction.
