If the unit is not charges every night, we get the 6 beep message and the thing won't move. this happens even when the unut was not used since the last charge
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
I had the same thing happen to my Digix Tab 720 last night. This happened after I reset the tablet to factory settings. I left it charging over night and this morning, it is working perfectly. Hope this helps.
Clear the alarm clock or take out the battery at night unplug it then if it beeps I would call that TV show that does the ghost thing I would be worried if that happened. Just kidding of course see if the alarm is on or if you have an alarm. Other when the battery is still plugged in and the power cord is still hooked up it could be the low batter or charged indicator letting you know it is charged. If it is the same time each night then it is the alarm clock that was set somehow maybe someone has a better solution. Check it out though. Interesting but frustrating I bet. John
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
that's not a good sign rarely happens just take it back to your retailer even without a receipt they should give you an exchange for the same or a similar unit.
Hello sir; Sometime this problem can be reset, just let's try, ; Press " clear mode ", "107", "stop/clear" key until screen show out sp mode then turn power off and back on again.
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
