Try these steps...
>> press the keypad menu
>> type the code *#6984125*# , it will lead you to phone internal settings, which has the following options, admin, network, internals, etc...
>> scroll down and select internals, it will prompt you for password..type the code in the message box *#9072641*# and press confirm,
>> once on phone internals,select test mode
>> from test mode menu; select video which is item 6, or type 6 and press ok to lead you to videos menu,
>> you will see a lists, which includes your update camera firmware. (item no 3)
>> type 3 and press ok and wait till it has completed its updates and says successful.
>> press end key to return to your phone menus,
>> you would want to restart your phone for the updates to be fully completed.
>> once restarted, select camera, or press camera button and check your camera...
please be noted that sometimes, other phones may restart after updating the camera firmware..
Tried to update firmware as instructed but it kept failing.
camera still doesnt work. Same message as before.
