I need to change my phone to tone it's on pulse and i don't know how
In GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Try the star key
I need to change my phone to tone it's on pulse and i can't figure out which button i pressed that got me to that option.
Hi. This is Shoaib Bukhari.
In some sets by pressing set button one by one you can see the option of tone or pulse. When you see this option select your desire by pressing up or down buttons. If problem solve then its ok. And in some sete only by pressing * key can solve the problem that is changing from pulse to tone or from tone to pulse.
I have to press 9 on my phone to let in folks at door, I've tried the menu / settings / hitting the * key, nothing seems to allow a TONE to happen, just that quick pulse.
Administrator Manual available athttp://support.avaya.com/css/P8/document...
See SYSTEM customization for setting default for all handsets ... Good Luck!
SOURCE: Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
SOURCE: VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
us, too. somehow it got switched to pulse this past weekend and we can't figure out how to switch back. don't see anything in the user's manual about it. now, none of the features of telephone systems will work at the places I call as they rely on tones to be able to select them.
