Blaupunkt IDC-A09 5-Disc CD Changer Logo
Posted on Apr 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Entered code says wait 1 hour - Blaupunkt IDC-A09 5-Disc CD Changer
Anonymous
Level 2:
Scholar:
  • Expert 137 Answers
  • Posted on Apr 05, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
137
Questions
Helped
58081
Points
390
When you add an IDC-A09 changer to a pre-2004 car, you should not need to enter any code, it should just plug and play. If you have added an IDC-A09 changer to a post 2004 car the you have probably got the wrong changer. Post 2004 cars *usually* need the IDC-A04 changer, which looks identical.
The IDC-A04 uses CAN-bus while the IDC-A09 uses VAN-bus wiring. The two are not interchangable.
xxxxxx xxx
Level 3:
  • Blaupunkt Master 5,117 Answers
  • Posted on Apr 03, 2010
xxxxxx xxx
Blaupunkt Master
Level 3:
Answers
5117
Questions
5
Helped
1319547
Points
15645
It most likely means you are entering the wrong code.
To reset, leave SWITCHED ON...UNDISTURBED and it will automatically reset after a while.
To check your code, post ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the metal casing.
Also quote the radio and car MAKE + MODEL
  • 1 more comment
  • Anonymous Jul 09, 2011
    I don't suppose you're still around on here at all?
    I recently purchased an IDC A09 to use in my Stilo, after the last one purchased from Ebay was a dud.
    The one I have now connects OK, and the mechanisms all start moving, etc, but I do not have the code.
    2 different sources have provided codes, but both were wrong, unfortunately.
    Do you have the means to generate a code? I am concerned that a past owner of this one may have set their own code or something, if that is possible?
    My details off this changer are:
    Serial: BP915034456839
    Part No: 7 607 769 150
    idc a09 Made in Portugal.
    Fitted to a 2002 Fiat Stilo Active with radio cassette factory head unit.
    Any help would be much appreciated!!!!
  • xxxxxx xxx Jul 09, 2011
    try her ukbookshelf.co.uk
    they deal with all makes including Blaupunkt
    They are currently assisting me with my problem, thanks regforge. I have just e-mailed them a photo of the barcode on the changer.
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
4helpful
Hey there i have a 1997 BMW 328i and i changed my battery n when i started the car up my radio said code wait andd now i cant get rid of it please help me fix this. thank you ...
Hi chris,
Code wait is part of the built in anti-theft system BMW has for the radio. The ignition must remain in the on position for 1 continuous hour. Usually rush hour traffic does the trick. You will need the radio code to enter into the radio after it displays "CODE". just enter the code according to the buttons listed 1-6. ie if it ask for 13556, just enter the digits in that sequence. Make sure you have the correct code. If 3 unsuccessful consecutive entries are made, you will have to wait another hour.
1helpful
My radio says "code wait"
Hi Robin,
You will need to leave the ignition on for 1 hour continuously. After 1 hour you can enter your radio code.
Jun 14, 2011 • 1997 BMW M3
How can you get your radio to work in you 1994 saab? when you disconnect the battery what is the next step to resetting the code?
Anti- Theft Lock
1. Switch on the ignition
2. Press the VOL/ ON switch to turn on the system on, CODE IN will appear in the display.
3. Enter the 4 digit code using the preset buttons. The system will now appear.
- I believe the code for your car is 5253, but you might want to call the Saab dealer for the code
If yu make a mistake while entering your code, finish entering all four digits. Press and hold BAND switch until CODE IN appears in the display. The correct code can now be entered.
NOTE: If you enter an incorrect code three times in succession, you must wait one hour with the Audio Sysytem turned on before making a new attempt. After the one hour waiting period, the system will allow only one code entry attempt. If the code entry is incorrect, you must again wait one hour before another attempt.
1helpful
I have the unlock code for my 99 saturn sl2 but i need the radio layout
Hello, you will need to enter your radio unlock code using these instructions.
  1. Press SEEK DOWN, SEEK UP, TUNE DOWN, or TUNE UP. The radio display should show 0000.
  2. PRESS SEEK DOWN to set the first digit.
  3. Press SEEK UP to set the second digit.
  4. Press TUNE DOWN to set the third digit.
  5. Press TUNE UP to set the fourth digit.
  6. If the code was entered correctly, the radio will display SEC (SECURE). The theft deterrent system for the radio is now active and normal operation may be resumed. If the code was entered incorrectly, the radio will display Err for 5 seconds and the LOC (LOCKED) will be displayed again. If LOC is displayed, repeat 1-6.
  7. If the correct code is not entered in 8 attempts, follow the next steps:
  8. 7.1. Turn ignition to ACC position. 7.2. Turn radio power switch OFF. 7.3. Wait one hour before repeating steps 1 through 7. If attempts to unlock the system are made before the one hour period is up, the radio will display INOP (INOPERATIVE). Continue to wait. If the ignition is not in the ACC position, power will never reset internally to allow itself to be unlocked. 7.4. After one hour, repeat steps 1-7.
1helpful
1994 900 s radio code
If the code is entered incorrectly 3 times then you have to wait an hour, with the radio turned on, you will then get 1 chance to enter the correct code. Get it wrong and you have to wait another hour before you can try again.
Check with the dealership that you have the correct code. They will be able to tell you if you give them the VIN.
How to reset the raido
There is a trick to the procedure. You have to turn the key to position 1 or the first stop on the ignition. Turn on the radio and wait between 2.0 to 3.0 hours for the radio to reset and ask for the code. From the owners manual. My 97 takes between 2:25 and 2.5 hours to reset. Every radio is different.
To enter the code:
After installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I
the unit must be turned on
Make sure the headlights are turned off to help prevent battery drain (please refer to page 2:6 for information on turning the headlights off). Enter the code again once this time has elapsed.
Ryan
3helpful
How to enter the code into a rover cc32 car stereo, its a blaupunkt 7 642 161 310 radio, i have the code but any button i press it goes into wait 1 hour mode. Thanks David
After you wait 1 hour, you can enter the code by pressing the presets one at a time until you have the code entered then hit the down pointer to enter the cose.
2answers
WHEN ENTERING THE cODE i MADE A MISTAKE AND THE INSTRUCTION CAME UP WAIT 1 HOUR. THAT WAS TWO DAYS AGO AND IT STILL SHOWS WAIT 1 HOUR Can you please advise on the action to take next. Thank you
have you actually left the ignition on one hour?
if not, do that and see what happens. One full hour without touching it,, key on.. theyre on a timer, it should come back and want you to enter the coder after that hour...
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
