Jabra BT160 Wireless Headset Logo
Posted on Apr 03, 2010
How to connect jabra bt3030 to laptop via bluetooth
I bought a jabra bt3030 and tried to connect it to my laptop via bluetooth, but the problem is, i can't be detected by the my laptop.
Thanks,
King
4 Related Answers
Anonymous
  • Posted on May 30, 2009
SOURCE: Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Anonymous
  • 8 Answers
  • Posted on Aug 25, 2007
SOURCE: connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
ironsmiter
  • 26 Answers
  • Posted on Jun 01, 2009
SOURCE: Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
Anonymous
  • 91 Answers
  • Posted on Feb 22, 2011
SOURCE: my lg prime will not pair with my jabra bt3030
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Hi I have an iPhone 4 and jabra bt3030 worked perfect on my iPhone but in my iPhone I tap forget this device and the device was gone! now I can't find it again! what should I do?
    • 1. Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. It is the button that has an image of a telephone on it.
    • 2. Click on the "Settings" icon from the main screen of your iPhone.
    • 3. Click on "General" in your iPhone's "Settings" menu.
    • 4. Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
    • 5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
    • 6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
    • 7. Click on OK on your iPhone
NEED NUMERIC PASSKEY FOR JABRA BT3030
According to the mfg. website, the default passkey is 0000.
Thanks.
2helpful
My lg prime will not pair with my jabra bt3030 bluetooth headset
5helpful
38helpful
5answers
Blackberry pearl 8100 and setup or work around to get jabra BT3030 to play music
I have a Palm 700w and just purchase the Jabra BT3030 and although the Bluetooth works with phone functions I cannot get the Jabra BT3030 to work with music functions. Is there a quick fix for this I am missing?
9helpful
5answers
Not able to connect Jabra BT 125 to Laptop
Correction to the above note...
You can connect your Jabra 125 to your computer's audio output and listen to music via the ear piece. You need to make the adjustments in the control pannel. Set the audio/sound output to the blue tooth. You also need to sync the earpiece to the pc via a dongle or bluetooth adapter on the pc. Works great...
Jimmy
www.CLSONLINE.org
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
